Originally Posted by Jojo
Hi all, so I came out of my 2003 Boxster S and needed to open again the car with the key fob, but the remote will not respond, and noticed that the red LED was flashing slowly, as in once per second and not like another working key fob I have, which flashes faster when pressed.
I've tried all I've read on this forum, as in key in ignition on, key out and press etc, but all to no avail.
I was wondering whether actually this key really needs to be re programmed at the Porsche garage? or maybe there is a way that I can make it 'talk' to the car myself?
As I said, the other key fob i have works fine with the car, and i also replaced the battery with a new one just in case.
Jojo
I have the same problem on my 2001 3-button remotes. One remote blinks quickly and works, the other blinks slowly, and doesn't work. On both remotes, I've replaced the batteries, replaced the three surface-mounted momentary push button switches, and reflowed all solder joints (including those under the battery holder). All this got the fast-blinking remote working completely 100% reliably, but the bad remote still with "slow blinking syndrome" still doesn't work at all.
