Old 11-08-2015, 07:18 PM   #3
DWBOX2000
I was lucky, the aluminum was not dented or gouged. From all that I have seen, even that can be fixed with bondo if the gouge is not to bad. I just sanded down the areA but tried to keep as much as possible of the existing. Cleaned with cleaning spray provided. Then primed slightly overlapping the area being painted. Them sanded with 320. Painted going over the primer and slightly over existing paint. Then did same with clear. The kit came with everything. Cleaning, humidity and temperature are important. Matched perfectly. How well it holds, time will tell. Currently my best looking wheel and the others are not bad. There is tons of stuff on the internet. Google painting boxster rims.
DWBOX2000 is online now   Reply With Quote
