Old 11-08-2015, 01:02 PM   #148
boxster
Simple: It doesn't need to be.
The LN bearing performs excellently without a direct source of engine oil; the 20K+ units running around on the street attest to that fact. And, if LN could think of any circumstance where an oil feed system would be advantageous, they are perfectly capable of producing one, after all, they make the IMS Solution kits, but they have never seen the need.
You are way, way overthinking this. We have customers that put less the 1K miles on their cars every year, and those cars are LN equipped; none have ever had a problem. Other customers with LN bearings average over 35K a year, with the exact same results. The system works, exactly the way it is designed to work.
This entire dialog entered the "paralysis by analysis" mode about a week ago..........
You are right,I do overthink sometimes,lol!! What I still cant do understand is why LN life their bearings at only 4&6 years respectively for the single and double row,or 50k and 75k miles.
Since many cars have done much more than that on the original bearings and their bearings are proven to be much stronger I would have thought they'd have a longer life
boxster is offline   Reply With Quote
