[QUOTE=Jake Raby;472579]Unless you are using the IMS Solution, then no plug is required with any other LN Engineering product. Why? Because the bearing has an inner seal that does a great job of keeping ANYTHING out of the IMS tube. Oil, air, gases (insert laughter here) or even smoke, after the engine explodes!
Last I looked Air is a gas, comprised of 78% N2, 21% 02 and various other gasses.
The gases in Earth's atmosphere include:
Nitrogen – 78 percent.
Oxygen – 21 percent.
Argon – 0.93 percent.
Carbon dioxide – 0.038 percent.
Reason: Add Definition
