Old 11-06-2015, 06:37 AM   #12
JFP in PA
Originally Posted by mikesz View Post
I have the 15qt round from walmart. works fine for me but I undo the drain cap so the air can escape I also usually put a piece of cardboard underneath cause you do get some splash. You gotta open the drain spout so air can escape or the oil wont flow into the drain pan fast enough and it will overflow. I don't drain back into the jugs I just take the black container to the landfill and empty it.
If you need to control oil splash during draining's, buy a short section (6 inches or so) or a 4-6 inch diameter PVC pipe, then drill about a dozen or so 1/4 diameter holes around the circumference of one end. Set the pipe in your drain pan, but not over the actual drain opening, and allow the oil to drop into the pipe and then run out into the pan itself; any splash with be retained inside the pipe.
