Originally Posted by Jake Raby
Ok Now this is something that has to be elaborated on. My understanding that as soon as the oil film is lost such as oil starvation, contact occurs and bearing is destroyed. You have some other magic? Who says we can't all learn something?
Thats what the other guys want you to think.. Its the ONLY ammo they have against the IMS Solution.
Too bad they are wrong, and an engine can run for 20 miles and see 7,000 RPM over and over again with ZERO oil feed and not fail.
I t can go further than that, but thats what was on the engine when I did the video, then I pulled it apart for evaluation. I have photos of the unit pre, and post the evaluation to show what it did with zero oil feed, and didn't even have a line attached.
I have video documentation of this. You will see it soon, with a story.
No, its available at my facility right now. Distributors have orders in place for more than 500 units already.
The IMS Solution is a permanent retrofit, it does NOT have and mileage or time lifespan.
The IMS Solution uses a DLC coated journal, coupled to the material that the bushing is made from, it takes extensive wear to create an issue with this.
This wasn't something that was developed over night in someone's garage. I had more than a decade of my life invested in the invention, and development before I was able to secure the Patent for the IMS Solution.[/QUOTE]
When I asked about lifespan I meant for the ceramic bearing retrofit kit. Will the bearings still be more prone to failing if the car's not used much? And will it still need changing after 6 years, irrelevant of miles?
Can I ask how much the ims solution will cost for the dual row?
