Maybe it's time to think about something that was discussed in the What type oil filter do you use thread. Oil filter filtration is not 100% they have a allowable particulate size that passes through them. Some of these particles are ferrous, this is why the Filtermag was developed. No ROLLER type bearing likes to have debris contamination. So continuous oil spray or splash lubrication has it's downside. I am not affiliated with or in any way compensated by LN or Jake, but the only bearing that has the clearance to allow this debris is the plain type bearing in the LN Solution system. Choose your own medicine.
