Old 11-02-2015, 04:58 PM   #123
KevinH1990
KevinH1990's Avatar
Here's a picture of the oil pressure sending unit: http://www.pelicanparts.com/techarticles/Boxster_Tech/90-ELEC-996_Cluster/images_med/Pic6.jpg To install mine, I found that I had to open the access port behind the seats and also put the top in service position and have access from the top.
To run the wire to the dash, I used some 16 or 18 gauge wire I bought at an auto parts store. I removed the center console and ran it underneath. Once you take out the console, the path is obvious. http://www.pelicanparts.com/techarticles/Boxster_Tech/90-ELEC-996_Cluster/images_med/Pic7.jpg
The entire article is on Pelican: Porsche Boxster 996 Gauge Cluster Upgrade - 986 / 987 (1997-08) - Pelican Parts Technical Article
