Old 11-02-2015, 04:33 PM   #1
KevinH1990
KevinH1990's Avatar
I think you may have posted on Rennlist and I provided a response on that forum. If that was you, you didn't mention that both the window and seat heater switches weren't working. Maybe someone spilled something there and the switches are gummed up.
If cleaning the switches as suggested by Mark T doesn't work, there are several other possibilities. The next thing I would check is the Control Unit Seat Heater (Relay) under the seat. You could swap the relay from the passenger seat since you know that works. You can also swap the switches from the passenger to the driver's seat to rule out a problem with the switch.
This article on retrofitting OEM seat heaters contains detailed information including diagrams and part numbers regarding the design and operation of the seat heaters: Dennis Vogel: Projects - Boxster Heated Seats
Here's the diagram showing the control module: http://www.dennisvogel.com/heatedsea...eatharness.gif
