Old 11-02-2015, 11:38 AM   #11
Gilles
You can pull the cover off your diff and remove and inspect the gears. Pelican has a great how to for LSD install. Just be sure to keep track of the shims you pull and re install exactly. The pic you have attached is of an LSD, yours will have the spider gears in the open diff.
+ 1
You should not be driving the car before you check inside the gearbox, because if something is loose inside and gets caught between the differential gears, you will have a catastrophic failure.. (not to mention the possibility of having an accident)
Gilles is offline   Reply With Quote
