Old 11-02-2015, 10:35 AM   #11
heiwaz
You can pull the cover off your diff and remove and inspect the gears. Pelican has a great how to for LSD install. Just be sure to keep track of the shims you pull and re install exactly. The pic you have attached is of an LSD, yours will have the spider gears in the open diff.
Thanks, I have seen the DIY in pelican to install de LSD.
So, you tell boxster S has got a differential like this:
Do you think there will be some clearance in parts 2 or 7?
heiwaz is offline   Reply With Quote
