Old 11-02-2015, 07:29 AM   #10
jeeper31
jeeper31's Avatar
Possible, but if you pull the fuel pump relay and jumper the pump (do a search for procedures) and still get no pressure, you have a pump issue as this bypasses the CPS.
Is this definite? I jumpered the pump and there was still no fuel pressure. I hooked up a test light to the #30 slot and there was power so I assume power is going to the pump and it is not working. Am I correct and does that mean it is definitely the pump?
jeeper31 is offline   Reply With Quote
