No - one of the ceramic bearing's biggest attributes is that it requires only a small amount of lubrication (the individual balls are as hard as he knockers of hell) & certainly the oil mist caused by the rotating masses of timing chains, crankshaft, cams etc. is enough. Actually, too much oil can cause "skidding" of the balls in the race.
Don't overwork this - as JFP and Raby say, keep good quality, clean oil in your engine and you wont have to worry about bearing failure. Just make sure the person who installs the new assembly in Malta is experienced in the LN IMS installation procedures.....
2001 MV Agusta F4.
