Thread: Boxster Died
Old 11-01-2015, 08:19 AM   #23
jeeper31
jeeper31's Avatar
Anything more than 9v 'should' operate the relay but why try? Just charge the battery to eliminate that problem. If you are measuring 11.67v with no load, it may be misleading because poor connections will show massive voltage drop when you draw power.
Did you bench test & compare the new & old relay?
How would I benchtest relay?
jeeper31 is offline   Reply With Quote
