Old 10-30-2015, 05:08 PM   #7
koosh
Originally Posted by Pirate50 View Post
Nice work, have all the supplies to do this myself, just need to find the time. Did you trim the carbon at the edges and holes or did you roll it inside. Your holes look perfect.
It does take some time but it's quite therapeutic and enjoyable when something comes out looking good!
When I'm doing it I let the cloth hang 15mm or more over the edge then trim right back, first using a dremel cutting wheel and possibly a dremel sanding disk, then I use a heavy grade emery cloth to sand right back to flush edges! Some of the pieces look better in photos than in real life (as does everything really....)
Originally Posted by tommy583 View Post
Looks great man!! I wish I was able to do that, I would probably ruin all mine trying.
Thanks! I get lots of spare pieces so if I do ruin anything I've got something to fall back on...
Originally Posted by Sammy986 View Post
Loved that quote. Legitimately loled. Also, good job!
Hahah thanks! Quite proud of myself for that one when I wrote it
koosh is offline   Reply With Quote
