Thread: ecu swap
Old 10-30-2015, 11:23 AM   #11
boxster
Yes, the ECU/immob/fob are programmed as a matched set, so you will have to swap all three for the car to run. This should let you pass the emissions test and then you can swap back to the modified ECU/immob/fob set. Just keep the second (stock) set for emissions testing.
I know this works because this is exactly what I do.
Cool, glad to know I'm not the only one thinking about this�� I think ill buy the set and see how it goes
boxster is offline   Reply With Quote
