Old 10-30-2015, 07:36 AM   #2
JFP in PA
Originally Posted by jeeper31 View Post
so I checked fuel pressure at rail by depressing shrader valve and got nothing. Then I put ignition to on and checked the fuel rail again and still nothing. You're saying it can still be the CPS and the only way to tell is to jumper the system and see if getting pressure by fuel rail?
Possible, but if you pull the fuel pump relay and jumper the pump (do a search for procedures) and still get no pressure, you have a pump issue as this bypasses the CPS.
