Old 10-30-2015, 07:08 AM   #2
JFP in PA
Originally Posted by jeeper31 View Post
But doesn't the fuel pump run when you put the key in the on position (not the position to start the car) ?
Yes, but only if the static fuel pressure is low; otherwise it does not run which is why you have to pull the relay and jumper the system to make it run on purpose for testing.
