Old 10-30-2015, 06:49 AM   #1
jeeper31
jeeper31's Avatar
When the CPS fails, I think the ECU 'thinks' the engine is not rotating. Therefore there is no need for any fuel.Therefore the fuel pump relay gets no signal.
CPS is not very expensive. About $90 in USA. The part number for mine(but verify for yours) is:
BOSCH - 0261210204
But doesn't the fuel pump run when you put the key in the on position (not the position to start the car) ?
jeeper31 is offline   Reply With Quote
