Old 10-29-2015, 05:49 AM   #5
Burg Boxster
Originally Posted by Maydose View Post
My headlamp stalk will not operate dipped or main beam without holding it back.
Headlamps do not work at all dipped.
I have a 2004 S Tiptronic without cruise....ie. 3 stalks.
Pelican have a switch stalk with 3 arms for $444!
Can't believe a small switch can be that expensive..
Anybody done a repair??????
Assuming you've verified both dipped bulbs (halogen system) are NOT burned out...
Issue sounds more like symptoms of a bad headlight switch... not stalk. Doubly so w/ litronic lights.
If so, repair part (though not inexpensive) should be less than half the cost of a new stalk... and much simpler to DIY. If you have the wiring diagram you can remove the existing switch and make a jumper to test the lights.
Good luck
"Cool Prius!"
- Nobody
