Thread: Oil Leaks
Old 10-27-2015, 06:03 AM   #1
pieter1
Oil Leaks
IMS seal, look at the oil filter if its wet can be cracked or pinched o ring. Oil drain plug (will leave a oil puddle), Or reseal the oil pan (RTV gets old sometimes)(will leave a oil puddle). The best way to look for leaks is clean the motor with degreaser, and drive it on a dusty road it shows up fast. If you have no oil puddles then it sound like it only leaks under pressure.
pieter1 is offline   Reply With Quote
