Old 10-24-2015, 01:13 PM   #14
Escy
The Audi and Boxster clutch plates are both 240mm so i'll be using a flywheel and clutch pressure plate for the Audi but clutch disc won't fit the G86.20. Do you know if the G86.20 and G87.20 clutch discs are the same?
I've found a G87.20 for a good price so I might go for that. Can I use the 86 outer CV joint on the 87 shafts?
Escy is offline   Reply With Quote
