Old 10-24-2015, 08:47 AM   #11
Escy
I was planning on modifying the bellhousing on my G86.20, was going to put a hole in it for the flywheel sensor and add a few more holes for the missing bell housing bolts (the majority are fine anyway).
You don't happen to know what type of signal is generated from the vehicle speed sensor do you? I'm hoping it'll be the same as what my Audi ECU will want to see.
All the trans options are open to me but I want to go the easiest route. An 01E is dirt cheap, and will match the engine perfectly but i'll need to fabricate mounts and shifter linkage so that's my least favourite option at the moment.
Escy is offline   Reply With Quote
