Old 10-23-2015, 06:40 PM   #11
dghii
Dave, I replaced mine about a month ago and choose not to mess with the parking brake cable so I left the hubs in place and removed/installed the bearings using a Harbor Freight bearing removing kit, it's actually pretty straight forward as long as you reinstall the bearings facing the right way… (so you won't loose the ABS)
Did you do rear bearings with the HF tool? I thought I'd previously heard about it being used for the fronts.
dghii is online now   Reply With Quote
