Old 10-23-2015, 06:53 AM   #1
gdotcvg
Look for black pieces of foam in vent outlets. From what I've read it is not uncommon for the foam in the AC/heat control box to partially disintegrate w/age. I suspect that may be your issue. I had a similar issue and just pulled the flakes from the vents w/ hemostats to eliminate the noise. Heat and a/c still perform well so I have not tackled the real fix of digging into control box (big job).
gdotcvg is online now   Reply With Quote
