Old 10-23-2015, 04:41 AM   #7
Seadweller
When did you do your last transmission ATF oil and filter change?
Is the ATF fluid level correct?
Regards
Markus
I need to go through the extensive service records that came with the car. The PO told me it was done "recently," so I assume within the last year or two. He evidently used some sort of "lifetime" fluid during the service. I'm not sure if the level is correct, but I'll need to have that checked too.
I would normally have gotten a PPI, but this car is like a time capsule, has only 36K miles on it, and the prior/original owner has maintained the car with an open checkbook and has the records that indicate such.
Maybe I'll take it to my local Indy that I've used on my prior Porsche's for a once-over.
Seadweller is online now   Reply With Quote
