Originally Posted by Steve Tinker
Under normal conditions, the fuel pump will start only for a couple of seconds when the ignition is first switched on - this pressurises the system ready for startup. If you are hearing the fuel pump run continually with just the ignition on (engine not running) then you have a faulty pump.
But if the pump was running continuously wouldn't there still be pressure in the rail?
