Thread: Boxster Died
Old 10-22-2015, 11:01 PM   #11
Steve Tinker
Steve Tinker's Avatar
Under normal conditions, the fuel pump will start only for a couple of seconds when the ignition is first switched on - this pressurises the system ready for startup. If you are hearing the fuel pump run continually with just the ignition on (engine not running) then you have a faulty pump.
2001 MV Agusta F4.
