Thanks for letting me know. In the rear, I think there is only supposed to be one fog lamp on the driver's side. As for the marker lamp inside the headlamp assembly, I will have to look again.
I did a little more checking. There is no ground on my right front turn signal. I must have disturbed something because it was working, and now some of the other lights don't work. I would bet that that the fault is common to these and a ground is often the issue. I may bite the bullet andbring it to a shop that has done some work for me.
