Originally Posted by Smallblock454
The clutch kit also doesn't include a dual mass flywheel.
If you decide to buy a new clutch kit, check SACHS or Valeo kits.
I would pull the transmission and check everything first. But if it's the first clutch i would say it's a good time to replace the clutch, because to replace the clutch is time consuming.
Regards from germany
Markus
Originally Posted by martsink
The clutch kit will only come with a bearing, pressure plate, and a clutch. You can get the clutch fork separately for under $50. If the clutch is showing some wear, I would just replace everything now, and save yourself the headache of taking out the teanny again.
Thanks. Is LUK flywheel a good choice if it needs replacing? Does clutch and flywheel kits usually include all the needed new bolts or do you have to buy them seperately?
Can you give me any Ebay links to the new clutch forks, what name is used for those? I only found some suspension forks when did a qucik search. Lastly, is clutch fork same part as release arm, a loved child has many names?
