The relay can be jumpered to get things going and test. I will try to find a picture for you.
Fuel filter in under that car about there the E-brake handle is. a PIA to do as the belly pan has to come off. and a bunch of stuff has to be loosened.
Fuel pump is in the tank up front...I think.
Jump the relay and see if you hear it. Check all fuses too.
This relay is under the dash.
