Old 05-23-2006, 04:00 PM   #11
Perfectlap
Perfectlap's Avatar
well the soft top cover is amust have for you blazing sun folks
I would attach this only from the front and rear, cut the doorhandle loops off with a scissors. Not good to be rubbing on the paint that often.
http://cgi.ebay.com/ebaymotors/1997-06-PORSCHE-BOXSTER-CAR-COCKPIT-COVER-ALL-WEATHER_W0QQcmdZViewItemQQcategoryZ50456QQitemZ806 7851262QQrdZ1QQsspagenameZWDVW
this guy should give me a commission!
Originally Posted by Wintermute
So you are saying that the swirl remover should be applied by hand? I thought a polisher was the prefered way of doing swirl removal?.
As for the swirl remover what I meant to say is that there are only so many times you can go the PC route to remove swirls. Probably why its best to start off with as mild a swirl remover that will do the job. If you still see swirling kick up to the next most abbrasive formula. This way you aren't needlessly cutting away clear coat.
Swirl removal by hand won't save you any clear coat and just give you carpel tunnel syndrome.
BORN: March 2000 - FINLAND
