Old 10-15-2015, 06:58 AM   #6
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
Since you did the work, do you remember if your clutch plate had springs in the frame? I had a clutch spring break and rattle in-between the plate and flywheel. (old Chevy truck) It was drive able, but it made a hell of a racket.
You note that you rebuilt the trans and had some issues. And that it made some noise and bent teeth. None of those thoughts are encouraging.
