Old 10-14-2015, 12:35 PM   #3
jhbaik
Thanks for quick reply!
The black & white part is a 1way valve & should be pressed into the small "tube" at the bottom of the intake crossover tube sleeve. That will probably cure the trouble code.
Thanks much! I reconnected and put the throttle valve back and reset the code by battery disconnection. Hopefully it fixes it. Test driving shows original strength so far. Again, thanks much for quick answer.
John
jhbaik is offline   Reply With Quote
