Old 10-14-2015, 11:41 AM   #13
BYprodriver
BYprodriver's Avatar
Base rotors have a spec where they can be turned, S rotors can't. There is 2 mm of allowed wear per rotor before Porsche says they should be replaced. You can get an idea because there is a lip at the top of the rotor, once it gets to 1mm per side they are done.
My "S" rotors have wear spec on them. Of course you can turn them, it will reduce the chamfer depth.
