Old 10-12-2015, 01:50 PM   #1
edc
550 Anniversary
edc's Avatar
It's just a grinding type tool on the end of a dremel, even better if you have an air tool. Don't overthink it. Whatever fits in the slot just push in the direction you want to grind out, the existing slot acts as your guide. Use a felt pen to mark where you want to grind to. Dust down the area then use some touch up lacquer or colour or similar on the exposed metal
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
