Old 10-11-2015, 11:26 PM   #11
Steve Tinker
Steve Tinker's Avatar
Originally Posted by Duezzer View Post
So the LN adapter would rid the vehicle of a the bypass - Is the bypass built into the plastic cartridge cover or up in the mounting area? - Just did on oil change but did not take a hard look - The spin on oil filter will have its own built in bypass?
If the stock bypass springs get week over time and end up bypassing the filter is there a way to change out just the spring?
There is no way to replace the spring in the stock filter housing, but you can replace the housing quite cheaply - about $20 IIRC.
2001 MV Agusta F4.
