Old 10-10-2015, 05:09 PM   #138
Ben006
Ben-Auto-Design
Ben006's Avatar
It's IN !
And working !
https://www.facebook.com/benjamin.nenert/videos/10207860314604181/?l=7273786639763200972
The idle is slightly higher, probably due to the fact that I didn't do an ECU reset, but I should !
I drove it for 1/2h without problem, but I need a hose clamp and some heat shrink since mine is not a final version ...
I did a test run, @25°c and 85% ambient humidity.
0-10 km/h: 0.99 sec
0-20 km/h: 1.90 sec
0-30 km/h: 2.53 sec
0-40 km/h: 3.16 sec
0-50 km/h: 3.74 sec
0-60 km/h: 4.35 sec
0-70 km/h: 5.02 sec
0-80 km/h: 6.59 sec
0-90 km/h: 7.47 sec
0-100 km/h: 8.35 sec
0-110 km/h: 9.28 sec
Elapsed Time
60': 3.41 sec @ 39.5 km/h
330': 7.63 sec @ 87.4 km/h
Miscellaneous
Max Speed: 113.4 km/h
Max Acceleration: 0.49 G's
It's not a hard launch, I went on the throttle after 2000rpm, and I think the road goes up slightly.
Sorry, it's metric
I will put everything back to original tomorrow, for the week, and do another timed run on the same road to compare (I forgot to do it before).
I will also try with a ECU reset to see if it improves.
Ben
Ben006 is offline   Reply With Quote
