Originally Posted by BoxsterLS376
Greetings all,
Just a quick update... I am going to get that video done tonight for the rear firewall... I started to hack up the cayman lid I got and realized that it is going to take quite a bit of work to "retrofit" that thing in and would have been much smarter to take care of it with the engine out
So FYI if you are doing one of these projects I suggest that once you are happy test fitting the motor into position, take some measurements and go ahead and finalize your firewall before you do the final installation on the motor! DOH!~
Oh and while you are in there fabricating go ahead and make a cold air box for your intake! Much easier to get access to everything without the motor in the way :/
So far so good! Time to go home, have a great weekend everyone!
J
After looking your car over as well as that Cayman piece I kind of thought the same thing - great minds think a like huh
Even with the firewall issue the car is pretty damn cool - and fast.
I'm still not convinced that the easiest solution isn't cutting even more of the firewall out and going back with all new but...............
