Old 10-09-2015, 06:56 AM   #2
F18febe
I just had this same exact problem on my 04 S. There is a small micro switch in the door lock mechanism that controls the window up and down. You can not just change out the micro switch. I got a used door lock mechanism from Woody and changed it out in about an hour. Works like a champ now.
Before you tackle this problem, I would buy new door panel clips (8 each door) because as you pull the panel away from the door, these clips tend to break. They get brittle as they get older.
Easy project. PM me if you have any questions about this.
'04 Boxster S - Basalt Black, Fabspeed exhaust and sport headers, UD pulley, Pedro's Bluetooth, 18" Cayman S wheels, Evo cold air intake, IPD plenum, 74mm TB, Ben's SSK with ICT shifter boot, Fabspeed ECU Tune.
F18febe is offline   Reply With Quote
