Ok now that I've calmed down some and lowered my blood pressure its time to come up with a game plan.
I'm going to pull the water pump because its making some noise. Squeals really bad until the engine warms up and then quiets down but I do have a small leak from the bearing.
Remove and test the oil cooler. How do I test the oil cooler?
What else should I be testing/checking?
Note that the coolant is in the oil and there appears to be very little oil in the coolant.
Located in Central Mass.
'00 Boxster
