Old 10-01-2015, 06:36 AM   #1
jpl500
1980 3.6 Ruf-look Targa for sale
Not a Boxster but still a Porsche so hopefully some interest.
It needs to go to someone who will drive it more than I do.
1980 SC Targa Ruf Look – Guards Red
170k miles on body, 40k on engine since top end
Asking $35k
Car is located in Connecticut
contact: patrick [dot] loria [at] yale [dot] edu
Engine:
3.6 L 964 engine w/ 993 MAF injection, 993 exhaust
Head seal update
Dougherty cams
Mocal front-mounted cooler
All new engine gaskets (2015)
Valve adjustment (2015)
New plugs (2014)
New distributor rotor/caps (2015)
Fuel injectors cleaned, new o-rings (2015)
Solid engine mounts (2015)
RSR rocker arm o-rings, new rocker arm mounts (2012)
Leak down August (1-2%; 6-4%; 2-2%; 4-7%; 3-2%; 5-2%) (2015)
New fuel lines (2015)
New fuel filter (2013)
New, collapsible oil return tubes (2011)
Brad Penn 20w50 yearly (every 1000 miles)
Suspension/Brakes:
Turbo tie rods
SS brake lines
Rebel Racing a-arm bushings (2013)
New front wheel bearings (2014)
New ball joints (2013)
New e-brake parts (2013)
New f/r sway bar bushings (2013)
Triangulated shock tower brace (2013)
Rennline lightweight battery mount (2013)
Front Monoballs (2012)
Drilled rotors f/r (2013)
New pads (2013)
Speed bleeders (2013)
New ER rear torsion bushings (2103)
Aligned/corner balanced Musante Motorsports (2014)
Sport tranny mounts (2015)
New rear endlinks (2013)
New CV joints (2013)
Advan Neova tires ~1000 miles since mounted in 2014
17” Fikse wheels w/ black centers
brake fluid (changed yearly)
Transmission:
Factory short-shift
Stomksi shift coupler (2008)
Tranny fluid changed yearly
915 shifts smoothly. Speed shifting from 1st – 2nd will result in a grind. No issues shifting into first from a slow roll.
Interior/Body:
No rust, bare metal repaint in 2000
Fiberglass f/r Ruf bumpers, genuine Ruf front lip
Interior rennline bits (2011)
Appbiz RS door panels (2011)
Lightweight battery/rennline mount (2013)
Rear seat three-point belts (2008)
New heating plumbing (2012)
Vitaloni Sebring mirrors (2012)
Original door panels, working electric flag mirrors, complete trunk carpet, Guards red headlight trim rings available to go with car
Receipts for everything. Can take additional pictures
PPI is welcome. Will help arrange at buyer’s expense.
jpl500 is offline   Reply With Quote
