Old 09-29-2015, 11:52 AM   #4
RandallNeighbour
There's a high likelihood that your brake backing plates behind the rotors. These can make an awful noise that's consistent or only makes a creak or squeak or rubbing sound when the suspension is compressed or decompressed.
check all four with the suspension loaded and unloaded. It's a common issue after the car has undergone all the suspension parts swaps you've indicated you've done.
