The headlight switch is the only thing that they both have in common. The chances that both headlights would fail simultaneously is slim to none.
As Jay said, clean the switch by spraying contact cleaner into it. Pelican has write up for removing the switch.
If that doesn't help or doesn't last long, you will need to replace the switch.
