Originally Posted by The Radium King
if momo then presume no airbag. in that case you need a resistor to fool the computer, or run with a warning light (if I recall correctly you need a 4.7 ohm half watt).
To defeat the warning lights just take the binnacle off and remove the light bulbs, takes about 15 min. You can also remove any other offending warning light bulbs then as well.
