AS I'm sure you've all figured out by now my Coolant reservoir finally crapped out. The pictures are of what I believe is the infamous gel that forms from mixing coolant. I found what you see under the reservoir when I pulled it out. There is no gel in the reservoir or the coolant I drained. Since this stuff forms when heated and the high point is the oil cooler, I am pulling the cooler to inspect for plugging from gel. Hopefully this should give me an indication of what to do next. I will use this excuse to upgrade to an S cooler at this time. Any thoughts or recommendations ARE appreciated. Thanks All.
