What is the wattage rating of the 0805s?
Also, how did you get the non-filtered signal to the woofers in the doors?
Ah, the good 'ol 0 ohm resistor trick...AND TL074s!This is like undergrad senior design all over again.
Might those caps you have '?' on be bypass caps? What are their values? It would make sense for the differential setup.
