Brake Pad Rattle..or is it dominoes?
Car is a 2000 2.7...When I drive over bumpy ground the front of the car sounds like a box of dominoes, if I slightly touch the brake pedal the noise stops (then returns when I stop braking) I assumed I had aftermarket pads in there & were a slightly different shape or the caliper pad springs were worn, but no, I now have genuine Porsche pads in (Brembo) & new springs & pin kit (also genuine)....didn't make any difference, it still rattles?? I know on a Boxster S the front pads have anti rattle shims that go inside the pistons but they aren't available for a 2.7 (but it appears they mite fit??) or could something else be causing the noise and stops under braking? I've also tried EBC back tape..waste of time. It aint as bad when cold but after 10 mins or so its terrible, has no effect on the braking though..ANY HELP...I WILL try it
