Originally Posted by jdraupp
Hoping that when you accidentally over filled the oil you corrected the problem? If you haven't you need to stop driving it immediately. I'm guessing that your aos is toast. Overfill of oil leads to premature failure. Pull it, pull your intake and see how much oil got by it. You could be in for a new mass airflow sensor, and o2 sensors if you're lucky. Do you do your own maintenance or do you have a mechanic you trust?
No it's still full. I just drove it home and have left it since
I will take it to my mechanic as I do not do my own maintenance
What else could I have damaged or what will I damage if I keep driving it.
