Old 09-20-2015, 08:08 AM   #1
Gilles
Originally Posted by landrovered View Post
I would inspect both sensors, make sure that the exciter is visible in the hole and that everything is lined up properly. Are your stake nuts tightened to spec (250lbft)?
Landrovered, the sensors are attached to the carrier and can be only installed in one position because the shape of their base is machined into the carrier, I will remove them again to clean them and ensure that their connectors are tight.
Also the axle nut was torqued to about 350 ft/lb +/- using a long 3/4" breaker bar...
